leeboy66
I just bought a 1977 and my headlights only stay down when the car is running. When I turn it off one or both flip open. Does anyone have any advice as to why this is happening?
leeboy66 said:I just bought a 1977 and my headlights only stay down when the car is running. When I turn it off one or both flip open. Does anyone have any advice as to why this is happening?
What is a handheld vacuum tester. What do you use?68Roadster said:Buy a handheld vacuum tester and start plugging lines and testing them. Could be a bad actuator/seal, check valve, hose....
Good luck!
SR'71 said:What is a handheld vacuum tester. What do you use?
