L
luvmy82
I need some help with trying to solve the mystery as to why my AC will not hold a charge on my 82 CE.
Here's some history of what has been done:
1) AC system has been completely and correctly converted to R134a. Previous owner did this.
2) When I purchased the car last year it was in February and did not need the AC until summer, and this is when I discovered it did not work. So, I took it into the shop and they did the following: recharged the coolant and found that the water control valve was not closing completely. They readjusted the valve.
3) They also checked any leaks with dye and black light and no coolant leaks were found. Chemical sealer was added for phantom leaks that couldn't be detected just incase.
4) Then, in June of last year I had to take it back AGAIN! Just blowing air. This time, they found that the heater control valve did not have any vac to it. Found out that the switch behind the glove box on the blend door was not moving enough to allow vac for the contol valve. It was adjusted and moved to control the vac. At this time, AC operated and temp was 47 degrees for the rest of the season last year.
Well, here it is spring again and checked for AC and ZIP, nada, nothing. Just blowing air.
Why can't the AC hold a charge? All the refrigerant is gone. Again.
Do I just go out and purchase an R134a charge kit and zap the AC when it's not working? Where in the hell is the coolant discharging from?
Who can help me out here?
