great!! big help thanx...was surprised this was such a common problem.I do have an aftermarket stereo that was in the car when I bought it..it started to not work for time to time..and finally stopped working all together..so this may be a cure.
Thanx again
Ronnie
If "SYS" is displayed in the LCD section of the instrument panel cluster after the customer installs a new (aftermarket) stereo, he will need to do the following:
1. Buy (2) 1 kilo-ohm 1/2 watt resistors. [Radio Shack part # 271-023. They sell them as a 2pk for .29 cents.]
2. Disconnect the negative battery cable.
3. Remove the receiver.
4. Connect one end of both resistors to ignition power. (Yellow wire in the car)
5. Connect the other end of one
resistor to the purple/white wire in the car.
6. Connect the other end of the second
resistor to the grey/black wire in the car.
7. Cover all connections and completely cover the resistors.
8. Reconnect the negative battery cable.
Picked this up a while back. I think it may relate to your problem.
