SwaveDave said:
An 8x10 " B and M plate type cooler is good for 26000 gvw. Jegs and J.C. Whitney has them. I installed two of them on the front of the BB's radiator...really dropped the temperature of the oil -- you can almost keep your hand on the outlet hose of the coolers. I think one would have been enough though. Approx. 70% of the engines heat goes into the oil and 30% into the coolant. So, an oil cooler is beneficial. I wouldnt be without one if i lived in the Sunbelt.
S.D.
Hmm... I was taking a look in front of the radiator, and I can't see room to mount even one, let alone two. The headlight actuators, vacuum reserve tank, and the path that the hood tip travels through when opening, seem to limit the space for a cooler.
Is it possible to mount one behind the radiator?
1979toy: same question, since you are dealing with the same year (maybe 1970 had more room up there - I've never had the opportunity to look): is there some space I'm missing, where the cooler would fit? Or is behind the radiator the only choice? Also, thanks for the thermostat idea - I looked in Jegs, and they have the thermostat unit for about $40.
I'm switching over to electric fans, so interference with the mechanical fan is not an issue. The only problem I can see with mounting it behind the radiator, is the air will already be heated, so it won't cool as efficiently as if it was drawing ambient air, directly. I can up the size, though, and maybe solve that. It also wouldn't have airflow from the fan, but I can add a separate electric fan to the cooler.
Joe
