1cooldaddyo
So I decided to bite the bullet and upgrade the passenger window on my '85.
I picked up a used scissor style regulator off ebay for $120 and put it in last weekend.
Problem is, the glass seems to be leaning too far in and none of the adjustments seems to help.
I'm thinking the regulator is bent or otherwise defective, but going from a ribbon style I don't have any frame of reference.
So I have a couple of questions for those who have done this conversion before:
1) once installed, was your motor right against the inside wall of the door. I mean in close contact, up tight, can't be moved any further inward.
2) Did your scissor regulator fit snug vertically?
When I installed mine, I put in the upper bolts first and it kind of hung from those and I was able to swing it back and forth easily to start the lower bolts.
