window sweeps
geogolf
brookville pa.
1990 L98 coupe green
has anyone bought the window sweeps that are on ebay if so are they any good or junk thanks for any replys geo
Provide a link. If they are the outer ones, they are relatively cheap fron the General.
I did. Already installed them on my 1990 coupe. Cannot say any bad on them. Fit well. Bought new for around $60.00 a pair.
thundervette did you have to rivet the sweeps you bought or did they go on lip of doort
geogolf,
they mount the same way as originals did - fix with clips to door internal edge, and I also riveted 3 pcs rivets per side - if need you pics - will post later - let me know
hey thunder if you could post a few pics that would be great thanks foyour help geo
geo,
here are pics - sorry for low quality,
in general - just a gap of 1-1.5mm at rear end of each side sweep is not OK - maybe it was just my bad luck with exactly this pair of sweeps...
For OEMs I think there will not be any gap.
I replaced mine last week (86 Coupe). Didn't even have to pull door panel off.
Used a chisel to remove rivets, used long straight edge screwdriver to help clips into holes, used 12mm x 1/2 in. sheet metal screws in rivet holes.
