lqueral
I had window tint film applies to all the glass on my 13 C6 by a company that has tinted for me before (they had always done a good job in the past). When I got the car back, all was OK except the upper part of the back glass, where there is a dot matrix that seems to have prevented the film from firmly adhering, thus making the area look a bit lighter than the lower part. The matrix starts off with smaller dots and they get larger as they go upward. Tinter says this is a common issue with no clear answer. I'm upset because I think it looks bad, as the "line" between the properly glued film and the part-glued is not a straight line, and that makes it look sloppy. I'm also upset because I specifically asked before job was done if the tinter had done C6's and was told he has done quite a few, but nothing was said to me about this problem with the rear matrix. Anyone out there experience same thing? Anyone had tinting and did NOT have this problem?
