S
stressed68
I have a small problem...the wiper door will not open
You can open the door with the override switch and everything works. If you try to use the wiper sw. the door just sits there. once the door is opened with the override, you can operate the wipers--turn off the wiper sw and the door closes....
Everything has been replaced..wiper switch, limit switch, vacuum hoses and etc.. The only thing that hasn't been replaced is the relay under the dash..it appears to be working correctly..
Is there something I'm missing....?????
