E
ernie d
Hi guys. I have a wiper door that used to open halfway then stop. However, now it won't open at all. No movement when i turn on wipers at switch AND wont move any with the wiper door vacuum override knob pulled under the column.
I have to manually pull the door up by hand or with screwdriver on end of actuator underhood.
What does that tell you when NEITHER the switch OR the override won't operate the door?
THANKS!
Ernie
THANKS!
Ernie
