fhturner
- Joined
- Jun 23, 2003
- Messages
- 218
- Location
- Birmingham, AL
- Corvette
- '00 Torch Red Cpe, 6spd, '90 Red/Saddle ZR-1 #279
I'm getting a "Low Wiper Fluid" message constantly in the DIC. However, I filled the reservoir shortly after I got the Vette, just about 2 weeks ago, and have hardly used it much at all since then. Looking inside the reservoir doesn't show much (it's so hard to see down in there!), but the level is definitely, noticeably down since when I filled it. Also, the fluid does not spray from the right wiper assembly when I press the button (the driver's side works fine).
Could these two things, the quick drainage of the fluid and the fact that it doesn't spray on the right, have a common cause? I was thinking the little hose might be disconnected somewhere, causing the fluid to drain out rapidly from there. Only problem is, I can't really tell where the hose for that side runs. Any suggestions or things to look for?
Thanks a bunch!
Fred
Thanks a bunch!
Fred
