Help! wiper motor just makes clicking noise
hoso
australia
1969 black
wiper motor makes clicking sound when i run a test on it , i have found that i have an earth problem because when i ground the body of the wiper to the engine my blower fan starts to work so i guess running a good ground will fix its and the wiper issue , but does the clicking sound mean i have a dead wiper motor as i do have power to it ruffly 12 volts at the yellow wire , can any one advise me what to do next can it be rebuilt and how hard is it to replace any comments will be welcome
Does the washer pump function correctly? I don't remember what the problem was on mine or what I did to fix it but it had to do w/ the W/S washer pump.
no the washer pump isnt working either that was going to be my next task , i was thinking of fitting a more modern style with a pump fitted within the washer bottle and hide it away so its not obvious , but i will try to test the pump today, chris
The pump is built in the wiper motor and won't work till the Wiper motor runs!!:thumb
grounds,Grounds,GROUNDS !!!!!!! Get a service Manual,Find them "ALL" And CLEAN them "ALL" from front to back of Vehicle!! Bad and High Resistance GROUNDS cause "Feedback" and "Will"do weird electrical things through the vehicle systems!!:thumb Damn,It's a 69 do them "ALL" or you'll be chasing your tail for a month!!:thumb:thumb:thumb
