ThunderVette
Please help on subject for C4 1990, thanks.
No need for that!! There is a small hole in the plug to tie a wire to!! I use a Guitar string,pull the old one out with the string hooked to it,tie the string to the new one and pull it back down through the column!!Are you replacing it? If you are you might want to snip the wire for the cruise on the old one before you remove it and use it to pull the wire from the new one through the steering column.
I use guitar strings to cut windshields out with too!!Junk, you NEVER cease to amaze me! A guitar string!!!! I will remember that for future use, now THAT is resourceful.
Nope,Not Kidding!!I don't have any photos,but the next one I take a few!!You've GOTS to be kidding. Really?
I use guitar strings to cut windshields out with too!!![]()
