b44d
The wipers in my 1964 start in the "up" position and go down when they are turned on, then go back to the up position when turned off. Is there an adjustment in the wiper motor or has the linkage been installed incorrectly?
When the motor is "off" and parked, the arm should be at the 3:00 position as viewed from inside the car, and the link arms at the transmissions should look like those in the photo below.![]()
Hi John,
I don't remember and can't make out from you picture if the positions of the wiper arms matter. Which arm goes onto lever first?
Jack
The driver's side linkage rod goes on the motor first, then the passenger side linkage rod; don't forget the spacer between the two rods on the shaft, or they'll hit each other and make a loud "clunk" every motor revolution.![]()
