Wire trouble
Mart86&04
New Jersey
86 silver beige met,04 spiral grey met
Can anyone tell me how to find the factory wires for the cd changer. My car was not equipped with one and I was able to pick one up. I just cant find the connection.
I do not believe that all cars came with the connection. If the car was not built with a CD changer from the factory, you will probably need to purchase a supplimental harness to tie into the existing wiring.
Marty,
I looked thru the '04 manual and if the harness is there it will be behind the carpet/trim panel that is vertical along the back wall of the car.
As Bob said, being an option, it may not be installed. Looks like it runs all the way up to the radio, may even be tied in with other wiring back there.
Pic attached for clarity
Cee
HI there,
Yes, the wiring is NOT there.
You will have to purchase the installation kit, and install the wiring from the passenger side electrical center and run it to the rear.
Allthebest, c4c5:hb
