8
88kfb
Have a problem with my third brake light on my 88 convertible. The lights are not coming on. About 2 months ago they quit working so they have been working at one time. Here's what I have:
Changed the bulb in the third brake unit. Tested the lights straigght from the battery, they work. Under dash, pulled third brake light switch. Check with meter, switches off an on. Good switch. Checked connector wiring, the purple wire is going to ground (I believe that the purple wire is common ground on corvettes). The pink wire with black stripe also is going to ground. That, I believe, is the issue. I am trying to trace the wire but have no idea where it goes!! Does anyone know if this wire goes to a fuse box or where I can locate an 1988 wiring diagram to point me to the right direction? I have checked with the other corvette forums but do not have an answer.
I do not really want to take the car to a dealer but that will be my last resort. Any help will be greatly appreciated.
