N
nj7000
After storing the vette for 5-6 months, during winter, it won't start right away in spring. Last year this happened and once again, just when I want to get it out to do some maintenance, of course it doesn't start! It's only happened one other time that wasn't the first time in spring. I replaced the coil, and module inside the distributor. I also checked the the rotor was spinning inside the distributor, so what else could it be? :confused I replaced the plugs last year also, and I know it's getting fuel.
I have another problem which may or may not be related. If you listen to the exhaust it sounds like the engine is pulsing, it's sort of a patting noise. I'm really lost here, any help is greatly appreciated!
