I'm sure others with much more experience will weigh in on this one, but given the information you'll have to start a logical troubleshooting process. About a year ago, my '90 would start immediately, and run for a few seconds and acted like it ran out of gas. After letting it sit for about 10-15 minutes, this sometimes repeated itself and sometimes started right back up. I went thru the whole troubleshooting list - checked fuel pump pressure - both at the fuel pump discharge and at the fuel rails, changed fuel filter, verified leak down rate of the fuel pressure,pulled fuel pump and cleaned strainer, replaced gas cap, checked spark, checked ohms to each fuel injector, cleaned throttle body and checked settings along with a few other things. After a couple of weeks of troubleshooting and narrowing down the problem, took it to a local dealer with an excellent Vette mechanic and he confirmed it was the computer control module. I'm not suggesting your problem is the same as mine, but the point is to set out on a logical troubleshooting journey and eliminate as many possible causes as possible until you hit on the actual culprit or get down to one or two possible causes as I did - at that point I had to get confirmation from the dealer as it was expensive to correct either potential culprit. Replacing CCM's can be very expesive and I didn't want to swap it out if I didn't have to. Some of the troubleshooting is easy - some requires basic mechanical skills along with some tools such as a fuel pressure gauge and Ohm meter. If you can post some other information on the problem - no matter how insignificant it may seem - it may help others zero in on a good starting place. Some of things I completed didn't actually solve the problem, but ended up being good P.M. which may prevent future problems. I'm sure you'll end up getting all the help/expertise you need on this forum.
