15:1 ratio is the textbook A/F ratio. In a perfect world that would be the case, but the world is far from perfect.
Hey people...I am including my dyno run graph that I completed on my car last friday. Notice the bottom horizontal curve how low it is against the fuel/air mixture scale. The second one from the bottom was performed with the air cleaner removed, a 4 inHg secondary spring, and shifting the tranny manually. All these values are at approximately 5,280' of altitude. The conversion to sea level comes in at around 75 to 85 more horsepower.As you can see in Gerrys case it made a BIG difference.
Shure.. I almost did that once on an import.. had 2 pans that looked very similar front wheel drive either a honda or a toyota can't remmber but they both had similat pans.. and I wasn't paying close attention and pulled the trans plug, oil changes get monotonus (spelling?)thats not all I do but I do alot of them being that I am one of the younger guys in the shop.. ANY WAY.. I knew as soon as I saw the red fluid I put the plug in right away then drained the right oil pan.. and re checked and added a small amount of trans fluid.. it's an easy mistake on those. but on a rear wheel drive usually it's easier not to make the mistake.. eh well you still came out ahead a vette beats any ford any day.. and I don't mean performance wise nessicarily because there are some fast fords out there..LT4hitsthespot said:Great reward for an idiot huh?
:LBoy...one can't get one past Scam...
Hey Gerry I live at ~4000ft. I have the stock jets tuned for sea level but I want to change them to the ones required. I believe Holley recommends 1 or 2 (can't remember at the moment) jet sizes per every 1000 or 2000 feet. BTW I have a 670 Avenger.
However, I am currently in San Diego visiting family and recoverring from a big scare with my father-in-law. He had a stroke, and things have been dicey since
Yeah theres a guy right down my street that has a chassis dyno that can handle up to 1300hp, but I don't know if its equipped with a wideband O2. I don't know of any other than him. He charges $50 for 3 pulls within 1/2 hour.Is there a dyno shop in El Paso?
If not...do you want to come up to I'llbequerky (ALbuquerque), and we'll help each other out?
Where can i learn more about the wideband 02's and how they work I vaguely remmber an instructor discussing these at an automotive seminar I went to about fuel control.. any websites or anything like that would be appreciated.. he was also talking (I was half asleep after work) about our 02's being basically a lambda switch.. and something about how the wideband varies amperage instead of voltage.. and somewhere a digital signal I dunno would like to know more though..
I am sorry to hear that, my prayers are with you and your family.
Ya know I just might be going up there in a couple of weeks.
