Bolisk
Before I start, I will say that I know that the guages and sending units are always out of wack. . .so no need to explain that.
I've had my 1970 350/350 vette for a three seasons now. In those three seasons, the cars temp guage has never read hotter than 220. Now when I've checked this with an IR temp gun, the actual temp at the thermostat housing is ~ 190 degrees. The temp on the radiator return hose (about half way accross it's lengh, shows about 181 degrees.
However yesterday, it was 90 here in the chicago area. . .and for the first time the cars temp guage read just short of the red area (250) on the guage. I nursed the car home and checked the same to places. At the thermostat housing it read 256 and was climing about 1 degree a second as it sat there at idle. At the hose it was 196 and climbing about 1 degree a second. The housing climbed to 286, and the hose climbed to 214 before I shut the engine down.
The car never boiled over.
The radiator intake (radiator to the block) hose was about 146.
Last year, I replaced the water pump, and had the radiator re-cored with the correct coper core. Car runs Mobile1 High Milage 10w30, and I have checked to see that there is nothing blocking the radiator.
Temp would drop a bit when the car is over 40mph.
So I have a few questions. . .
1) I know that big blocks have over heating problems. . .but is overheating normal for small blocks as well?
2) What defined over heating? When the car boiles over, or whenever the car is hotter than a certain temp.
3) When does the temp become a potential problem for the engine. . .ie. cause damage?
4) Is there anything I can do to improve this. . .without adding electrice cooling fans to the front? Basically, keeping the car stock appearing is critical to me. I can't imagine these small blocks had over heating problems on a regualr basis when new. . .any ideas as to the potential problem?
Regards,
JonR
Regards,
JonR
