WTB 88 chip
Chip
Need to find a stock chip for a 1988 automatic.​
Thanks​
Hi
I noted your ad and although I don't have a chip I wanted to mention that
here are several stock chips depending on your axle ratio. You need to get the correct one for that ratio. Hope his helps in your search.
Cheers
Gary
Thanks Gary appreciate the info what i'm needing is a stock chip inorder to piggyback a custom chip due to me changing out the motor and adding a super ram. My rearend is a 2.59 which will also be changed. My car came with a over the counter chip and don't know where the stock chip is which i need when i have a custom one built so it can be piggybacked with the stock one.
