ss396t6
- Joined
- Apr 15, 2008
- Messages
- 60
- Location
- Texas
- Corvette
- 1970 Corvette LS-5 convertible, green/green/black
Parts questions. I'm looking for used, original Corvette parts for two 1970s and one 1972. I would like to see photos if possible. PM and/or email me:
-1970-1972 original master cylinder cap or caps with the words USE DELCO SAE J1703 BRAKE FLUID on one of the domes and SERVICE WITH DELCO PARTS on the other with no pressure relief tunnel between them.
-1970 original chrome oil cap or caps that has the S stamp on the center rivet. No other stamping visible. Has square rivet with a depression in the center of the square on the underside.
-RC-15 AC radiator caps original with indented center brass rivet, original
-RC-26 AC radiator cap, original only. No reproductions.
-1970 original gas cap, 'Sealed' on cap (no other words on cap), SM stamped on underside
-A70 or B70 original expansion tank
-Door courtesy switches with SX on the plunger heads
-Alarm switch. Similar to door switches with SX on the plunger heads.
-1970 original console gauge w/o gauges, 2 needed. Nice, no damage.
-1970 January dated T-top bags, black
-Oil dipstick with only the words ADD and FULL with an M stamp and black button, 27-5/8" long
-Trico wiper blade holders
-Steel exhaust tips with either the welds running down the seams on the undersides or no welds on seams but welded on rear perimeter. Pipe has 1" long slot on one side and a V opening on the other. No numbers stamped on them. No stainless.
-Stainless steel license plate frames with the spring steel tangs that hold the plates in. Need two. The originals have patent numbers stamped in small numbers on the tangs. Might be hard to see if there is rust or grime on them.
-'M' headmark bolts for 1970-1972 intake manifold.
1970 black right hand lower dash pad, need nice one. The 1969 had no stitching on the sides or around the map pocket, 1970 had stitching on the sides and stitching around the map pocket and the lower left corner protruded further out than the 1971-1972 issues.
Thanks,
Scott
Thanks,
Scott
