rrubel,
I don't care if it's dirty or incomplete. I can use all the stuff off of mine.
My concern is twofold; the throttle shaft and it's bores must not be worn and the arm must be of the same configuration as mine. I found one some time ago but it turned out that there are two types of linkage arm configurations.
Can you take a picture of the linkage arm and post it? If not I will take a picture of mine so you can compare it.
Did you remove this TB to use an aftermarket unit and if so, was the car idling down okay? When the throttle shaft or its bores wear, the butterflies hang, or something, causing a high idle. That's why I'm replacing mine.
Thanks very much for your response. If it is inconvenient for you to take a picture and post it, let me know and I can post a picture of mine this weekend.
Also, of course, how much are you asking for it?
Thanks again,
Doc
