eants
I'm seeing more and more people talking about how great an X-pipe is for performance. Is it possible to install one on a '76. BTW. The cat is already gone.
Unless someone is familiar with your system and can tell you the best location, experimentation is the only way to properly determine position of the cross-over pipe. If you're not looking to squeeze every possible amount of power from your Vette, such as a race car, the positioning should have a noticeable effect on your power output, but the noise levels should, especially if it is placed as far rearward in the system as manageable.... increasing the length of a header collector often improves power below peak torque without sacrificing high rpm horsepower.
In terms of street exhaust system design, increases in exhaust "collector" volume can be achieved by the use of an exhaust cross-over or H-pipe (Note: "X" pipes are the current rage. Ken ) that adds volume without restricting exhaust flow. The proper size and positioning of an H-pipe has often proved to be not only worth significant increases in power but also contributing to sound level reductions as well.
