93Rubie
We'll I managed to do it, I got a set of J55 brakes, and will be getting a set of Z07 springs/bars from 92 with a blown engine. Everything to do the complete swap out on my 93 that is FX3 only at this time. No LCA bushings as the donor car has 227K on it. I think I'll be fine with my 60K bushings for the time being. I'm going poly in the future anyhow. Once I get this stuff on the car, will it sit about the same, higher, or lower? Ground clearance wise as well as wheel to fender gap? I'm getting the Z07 shims for the springs so I can set it up according to the FSM. Reason I ask is, with having the car apart it would be a good time to lower it some if the Z07 does not let the car sit lower. One other question is the shock tuning on the FX3 shocks the same for the Z07 and FX3 suspensions? I would assume so, but you know what they say about assumptions.
