I apologize.....I was mistaken about the chart here. It does NOT contain the various spring rates and codes.....just the rates or stiffness in one of a couple methods of labeling.
Below is a copy of the chart that has the codes to match the spring weight/speed. There is a softer rear available...shocks DO have a little to do with it, as they dampen the ride. The first sensation that the road gives you is the shock...the remainder of the suspension action is more what the spring is doing....allowing lots of travel or very little. The flat springs barely move while the big arc moves like an archers bow.
Note the ID of each spring and then note the #per inch.
Then look at that ID over the various years to determine which are compatable with other cars besides your yr model. You will see the same rear on many different yr models. Hope this helps.
here is a link to the chart location. Not sure if that will work....below is part of the chart. I tried to copy/paste but it wants to un-align itself when pasted.
http://f1.grp.yahoofs.com/v1/ABYzTf...96) Corvette Composite Leaf Spring - data.txt
FRONT SPRINGS | REAR SPRINGS
Year RPO N/mm #/inch I.D. GM part | N/mm #/inch I.D. GM part
1984 FE1 63.5 362 HMZ 14106617 | 72.0 411 BMF 14045705
1984 FE1 66.5 379 HMZ 14106617 | 72.0 411 BMF 14045705
FE7 102.0 521 BMB 14045782 | 87.5 499 BMH 14045786
1985 FE1 54.0 276 HKX HMP 14094458 | 39.9 228 ...?1........ - not microed - NYR ?? RCA
FE7 63.5 362 HMZ 14106617 | 57.2 326 NYU 14080196
FE7 66.5 379 HMZ 14106617 | 57.2 326 NYU 14080196
1986 CPE FE1 51.8 261 HMP 14094458 | 39.9 228 NYR 22112253
CNV FE1 54.4 278 HMN 14094457 | 39.9 228 RCA 14106787
