Hi there,
Ok, sure, first Z51 is the handling suspension on coupe and convertible. This has 44mm monotube shock absorbers, power steering cooler, larger antisway bars.
The F55 is better for some people, because there is the advantage of being able to have that boulevard ride, with firm ride quality and control when needed.
Now, can you take the best of both worlds???? Not from the factory, unfortunately.
My suggestion here, is that if you want the cornering of Z51, but the control of F55, do the following.
Purchase the F55 ride control system, and then add FE4 anti sway bars from the ZO6.
This will give you 9/10ths Z51, with the adjustability that you would like, yet still corner like a race car.
I hope that this helps, c4c5
