ZR1 Weight
Hi Bret,
According to GM specs the ZR1 comes in between 3485 and 3540 depending on the model and options.
We have weighted only 10 cars. A small sample but helpful. This was done by a manufacturers sponsored racing group housed here in Atlanta back in the mid 1990's. Their scales was electronic accurate to two pounds.
Truck scales have proven to be off considerable more than this amount. I understand that 7% to 13% is very common from weight center to weight center and even larger amounts in some states.
Here are the results: Fuel load - 2 gallons
1990 ZR1.........................3522lbs
1990 ZR1.........................3534lbs
1991 ZR1.........................3501lbs
1991 ZR1.........................3512lbs
1992 ZR1.........................3517lbs
1993 ZR1.........................3521lbs
1994 ZR1.........................3502lbs
1995 ZR1.........................3498lbs
1995 ZR1.........................3503lbs
1995 ZR1.........................3490lbs
ZR1 and the Callaway TT weight in about the same. Both are too heavy but that was the best technology offer from the manufacturers production during these time periods.
Both are still great cars. Doug Rippie and several other used lighter components/parts on many re-builds for better performance like with the 368 cu inch set up that was mentioned here.
Hope this helps...
Take care,
Stan
