italian job
Hi all; today I have my plenum removed because I had a suspect something on the secondary working not very well (not too much difference between normal and full power key position).
Looking inside the intake ports I probabily found the cause: secondary valves are not on their places.:ugh Someone removed the butterfly valves... I know many people do this job, but what are the results?
I understand removing secondary means engine will use all 16 intake valves also when in normal power key position, so we have a 32 valves engine at all times. This maybe sound good, but I'm not too sure is really a good thing.:confused
Also looking inside the ports I notice primary ports are clean but secondary ports are smoked, what this means?:confused
I want to restore original secondary port throttle valve working way, so I'm searching for all 8 butterfly valves, new or used.
