Richard454
- Joined
- May 17, 2003
- Messages
- 28
- Location
- Atlanta,GA
- Corvette
- 87coupe,(2) 65 convert & 71 LS-5 ,M-21 convert
ZZ502 Deluxe
Complete-Carb to oil pan
Hi-torque starter, Alum waterpump, Holley 850 vac and HEI dist. w/ wires
Has about 1k miles on it then was upgraded abd painted Chevy Orange.
-New Comp Cam dur @.50 242 Int and 248 Ex, .612 and 622 lift
-Crane Hi-lift Hyd Roller Lifters (#13532)
-Comp Cams Pro Magnum Roller Rockers
-Heads decked to raise Compression to ~10-1
-Heads port matched
I have two sets of Valve Covers- Stock looking stamped steel (require double gaskets to fit) and Chevrolet “racing” aluminum tall Valve covers (I painted one Black- but will strip it back to natural Aluminum. I also have a brand new Centerforce flywheel.
This motor should produce somewhere between 575 to 600HP.
A 'stock' ZZ502 Deluxe is somewhere in the ballpark of $8k. This motor has over $1800 in parts on top of that. Valve covers alone-are almost $300-and have been modified w/ baffles.
$5500
email me Richard454@comcast.net
-Heads port matched
$5500
