'08 corvette problems
georgew386
port orange fl 32128
1992 black rose cv
'08 corvette sometimes won't come out of park button cannot be released until several tries. also don't believe ride control is working. rides like buckboard. any help appreciated
I believe that the gearshift problem is a common one. My daughter had a 2005 Bonneville with the same thing. I'll to see if I can find some info to help you.
There is a microswitch tht, when you step on the brake to shift out of park, that doesn't not make connection. this switch MIGHT be able to be adjusted, But, more than likely, will need a little add-on to the end of it to make that a more positive connection.
Hope this helps.
