skitch
Ok Guys, My 90 model convertible has this 1 to 4 shift pattern and I really don't like it. So how do I disarm this thing?
It's my understanding that the plugs are located on the drivers side of the transmission, is this correct? I've saw the pictures if the plug and I believe I can get onethat will work local.
On a 90, you don't need to buy anything, just disconnect the CAGS solenoid on the side of the trans. It's only the 96-up cars that require a "skip shift eliminator" because, when you pull the solenoid wire, the ECM sets a fault code.
After you pull the wire, you'll still see the 'one-to-four" light but the system won't work.
Or....stop short shifting in first gear. Once you do that, you'll never get skip shift.
For the most part, it's people who can't drive a manual properly that have trouble with skip shift.
It took awhile to get used to it but the way around it is as stated,wind it up abit but every once in a while you do get stuck going from 1 to 4.What bugged me the most was I was always looking for the light.I replaced the chip so now I dont have to deal with it.........................(snip)
Now that was an interesting bit of history. Thanks for sharing that!!!
Scott
So am I correct in reading that I can just disconnect the CAGS on a 1995 LT-1 ?![]()
I have read conflicting ideas on this during the past.
I had no idea, figured it was for gas milage. Learn something new every day.![]()
Uh well...skip shift does, indeed, improve fuel mileage if the car is driven in a manner that it enables on a regular basis, however, the main reason why skip shift was developed in the first place was pass-by noise, not CAFE. Consider mileage a "secondary" benefit of the system.
