W
wildman
Do I need to change anything other than the Thermostat to run cooler?? Still leave the fan settings the same and the computer settings??
I knew I should not have answered this thread. If you want it to boil, use a 160. I fail to see how a stock Corvette can get away with a 160 unless its a 1953 with alky coolent. This must be why I`m always asked at what temp does my Vette run. My 62 FI car uses a 180 and runs 170-180. My 68 L88 uses a 195 and runs at 190-200, The 84 and 86 also uses the 195. As you can see I do have a couple. We also sell automotive parts and service ALL cars. The trick is to hold the water back in the engine to allow the radiator time to cool the water before it returns to the engine. A 160 will open faster, but if you dont have a huge radiator and a bunch of trick junk, it`s going to boil.
:BOWhawaii-5-lo said:hello there,
they are designed to run this hot so the car has low emissions.your car will run cooler if you reprogram the computer to turn the fans on sooner,this is not some elaborate re-engineering,its like changing the temps on your refridgerator,you just want it cooler.a hot motor sucks at the track and theres no two ways about it.ive lowered the temps on all my cars and my friends do the same.the track times all drop.the other good thing is the under hood heat is drastically lower so the vacuum hoses and plastic dont rot and fade as fast.getting it to run right at 160* is tuff,but if you change to a bigger radiator you could do this.i agree about beating the dead horse,if you want it to run cooler change t-stat and turn fans on early if not leave the horse alonelater,Todd.
the heat killed my L98 and the heat kills my LS1 also.
later,Todd.
