Hi there,T&L said:Hi all Hey C4-C5--is a 180 ok for a stock motor? Or is it best to leave well enough alone? I was just wondering--I can see 160 being to low. Mine runs right at 192-4 all the time.
T&L
HallenTi said:I have read that using a thermostat of a lower opening point will indeed make it open earlier (at a lower temperature), but since the radiator is the actual thing that determines how cold/hot the coolant gets, the thermostat opening temperature has no affect on the running temp of the cooling system. This makes sense to me, but I am no expert.
Vettefan87 said:That is about half true if you ask me. That is correct if you are just sitting in traffic the car will eventually warm up to whatever the fan temps are set at, but at cruising speeds if you had a 160 Tstat it would reduce engine temps significantly. I am currently running a 160 Tstat and have my fans set to turn on at 175 so my car runs very cool.
