michael broyhill
if I remember correctly....and I could be wrong, it seems to me that it is held in place by a screw as there is a metal tab on the end of the seal. The rest of the seal is held in place with the rubber adhesive. Use the black if you can as it will hide better than that yellow. then the seal has the little plugs that push into the door around the perimeter. I checked for photos and didnt have any. Car is up on lift at the up position and no chance to move stuff around to get to it.I am installing wetherstrip on door it has a clip on top of door post is that held in place by top rivet door post felt
