Stingray6392
New member
I recently inherited my Dads '63 coupe that has been garaged since @ 1972. It's was a project in the works that was never completed, so I'm trying to gather all the information available on the car. The VIN plate and trim plate are intact, however the engine plate is missing. It was probably removed during the off-body restoration that was done in the mid 70's. The transmission and housing #'s appear to correspond with a '63, T10-7D with ID# 3813490 and the engine bell housing appears to be from a '63 as well with #3858407, however the only #'s that I can find on the engine block are on the bottom of the block on the drivers side - #3858403 - which I'm unable to locate for clarification and on the top of the block by the flywheel are the stamped #'s 18W360314 and serial #V0510EP. Any help on clarifying the engine would be GREATLY appreciated.
Thank you,
Jeff
Thank you,
Jeff
