Question: 1967 power brakes master cylinder
oagusti
New member
white lake , Michigan
2023 c8 artic white, LT3 red interior. 1967 c2 silver pearl, red interior
Master cylinder make a gurgling noise when pressed inside the car. Brakes otherwise seem ok.
Failing master cylinder??
Any sign of leaks inside or outside of the firewall? Fluid full? Watch the fluid inside the MC with the lid off when someone pushes the brake pedal. It could also be that brake fluid has leaked from the MC into the booster. Pop out the check valve and have someone push the pedal down while you listen.
Tom
I finally replaced the master cylinder and the booster with original like replacements. Turned out the master cylinder was in fact leaking g into the booster
