Bolisk
So, I've noticed a few things with the M20 trans that I would like some input on.
First, with the car runing, but at a dead stop (i.e. breaks fully applied), the clutch petal fully depressed, and I want to shift from a forward gear to the reverse gear. . .in many occasions I cannot get the Revere gear to engage. . .I have to shift into second then into reverse. Same thing happens when I want to shift into first from reverse . . . sometimes I have to goto second before shifting into first. Is this normal for a 1970 M20. . .or do I have synchro problems?
Next, I have noticed that on occasion, when the car is at a dead stop (i.e. breaks fully applied), the clutch petal fully depressed, and I wan to shift from a forawad gear to reverse (without shifting into 2nd first), it sounds as if the gears are grinding!! It's almost as if the clutch did not disengage completely. Is that an accurate assessment? Is it adjustable? I am I looking at a trans rebuild?
Note: the car runs and shifts smoothly through all forward gears. Only have issues switching back and forth between forward and reverse.
Thanks,
-JR
Thanks,
-JR
