Its not only Vettes, but all automatics that utilize a shift cable....noticeable whenever a car produces symptom of hard starting or slow cranking...The starter most always gets the blame in this situations and probably 75% of the time it was not the starter...We sold one of the best starters in the Nation. However selling the best don't always satisfy a customer when they can buy the 'lifetime' down the street...Depends on whose life its measured by...In Detroit its not very long...Anyway broken shifter cables with a white corrosion on the broken ends show that the engine is seeking ground wherever it can find it. These can be anything including emergency cables, shifter, and even brake lines. This happens when the primary grounds are corroded and over time the get thin and break from carrying the starter load...and its not the battery either but the ground that needs the attention...This so called 'heat soak is a incorrect diagnosis as everything gets hot and every time too, They didn`t crank hard when new...clean the grounds and especially the one right under the battery attached to the cross member...no one does however
