K
KWB
Have a friend that purchased '74 4-speed 454 big block Coupe (yellow) he is trying to document. He says that he has the original factory build sheet, but is unsure what gears are in the rear end or what the RPO codes stand for. It also has a couple of items on it that I am not sure are factory (i.e. side pipes and an alarm under the fenderwell that uses the factory ignition key to arm). The valve covers have "MT with the chevy bowtie" on it, which sounds like they may have been replaced and possibly a new cam installed.
Any words of wisdom and what to look for would be much appreciated...many thanks!
