jetset0045
Active member
I'm going to be doing some engine work this fall, mostly top end stuff, with heads, cam, intake, carb, etc.....and thought this would be a perfect time to eliminate the points and go with an HEI electronic ignition....but i'm a little unsure about the wiring that will be involved in this swap, and what hardware i will need to buy.....any suggestions or guidance.....?
thanks in advance....
