Kevlap
New member
I need a 700R4 trans and crossmember for a 76 coupe.
You could use an '82 crossmember if I remember correctly.![]()
You'll need the driveshaft from an 82 corvette. The TH700R4 is longer than the automatics used in previous years.
You can use a 1982 crossmember. One thing to note about it: it has a single 'cutout' for the exhaust pipe on the passenger side. The 1982 had a single catalytic converter. So the exhaust makes a Y shape into a single pipe before the crossmember, then an upside down Y to go back to dual exhaust tips after the crossmember. Something to think about.
Good Luck!!!
