- Thread starter
- #21
C
curtis
I'm no expert, but pressure readings should be taken with the unit running and the system stabilized. So let it run for a good ten minutes then get readings. It is normal to have higher presssure on the low side with system off than with it running. this is because the total charge equalizes when off and when you start it up, more freon is on the high side of the compressor causing the low side to stabilize lower than when it is off.
