78pacecargirl
I took my car to my mechanic because of an annoying squeak. It's audible while driving and is consistent with the rate of speed. Like a metronome, the faster I drive, the faster the squeak. When I apply the brakes the squeaking stops. In 2007 I had new brake lines, hoses and calipers installed to address chatter when I turned a corner. Turned out that problem was just old differential fluid. A costly repair that shouldn't have been. They did, however, find a broken clip that held in the axle, so that was replaced as well as the trailing arm bushings.
My mechanic remove the wheel and put the car in gear so I could see a slight wobble of the whole assembly, and hear the squeak of course. The pads are fine. It was closing time so he said he would work on it Monday. Please help me to understand what the problem could be. Warped rotors come to mind. These rotors are riveted and have never been removed/resurfaced to my knowlege. The wobble is present on both sides. Am I in for a large repair bill?
Thanks for any info you can provide. :confused
