21st
New member
So about 2 years ago I purchased a 79 Corvette which I knew had some problems but I just had to have it. The interior is pretty much all original and falling apart. She runs alright and there aren't a ton of electrical problems but the blinker doesn't work and the hazards don't work. Some of the gages don't work. There is this buzzing that happens when I turn the car off. I have a disconnect switch installed on the battery because it dies within 24 hours of turning the car off. I have tested the draw on the car and there is no current draw so there isn't a good explanation of why the battery keeps dying. So I've read on here that it isn't an easy job to replace the harness but that was my plan as I tear out the dashboard and gauges to replace all those. I guess I'm asking if that is a horrible idea just to replace everything. Or should I just fix one problem at a time? I also have wires and cables hanging out the bottom of the dash I have no idea where they go or what they go to. I'm just looking for advice on how to start and the best actions to take.
Sorry if this is kinda of all over the place.
Thanks in advance.
Jamie
Thanks in advance.
Jamie
