401KVet
The antenna/antenna nut is off center in the hole at the top near the rear window. This is where the antenna comes up. When I purchased the car, my 1st Vette, it was already this way. Now I would like to correct it for looks. All works ok with the antenna. As you can see in the photos, what I think is a nut, is off center. I don't know anything about the antenna, so my question is IF I lossen what appears to be a nut there on top, could I move it over and center the hole and then retighten?? I really don't want to mess anything up on the underside that would cause things notto work as they should. Thanks for any help...
