Zero1Niner
Decided to get started on my auto to manual conversion tonight on my 1981 Corvette.
Here is are some photos of the progress.
Remove this bolt at the rag joint. I needed to completely remove it to get the steering column shaft out.
Definitely remove the seat. Easy, and would be a pain in the butt if it was there.
Remove the panel under the steering column.
Remove the bolts at the firewall. There are 2 more bolts at on a bracket that I didnt take a photo of that are holding the steering column also.
Remove the a/c duct (really easy).
Need to disconnect all of the wire harnesses from the steering column. There are quite a few.
