hoodun
New member
I just bought a 1981 Vette for 2k. White w Red Interior. Its missing T-Tops, carpet is faded (was going to try carpet dye for this), and also missing emblems. It hasnt been on the road for 12 years, has 58k on it. It is currently non-op in CA, was last on the road in 1998 and was sitting in an alley. Though it doesnt look too bad. I think it has hope. It started right up and I drove it a block despite the rough engine.
The car is all original so Im going to stick with the ECM unit. I want to keep it that way since I'm in CA and dont want to replace the carb distr as some people mentioned doing on here. I want to try to pass smog with the orignal setup.
Engine runs real rough. There is no major smoke coming out the back. Just a tiny bit of grey smoke from the rough engine, I believe. Sounds like it is not running on all cylinders. The wires are really old looking... I'm starting with a basic tuneup (spark plugs, pcv, wires, fuel filter, ...?)
Check engine light is always on so I am going to check the computer codes after researching what that entails.
Headlights will not go up and take a while to go down. I already found a diagram on here for this and will troubleshoot, but not my priority. The rough engine is my priority.
Also the horn was cut because the alarm was always going off. Prob after the stolen T-tops? The seller mentioned this to me. He bought a new battery for it the day I looked at it so I think it may be killing batteries. Just a guess. I'm sure hes not telling me everything.
This is just an introduction to my new project. I'll post photos when I get them. You'll hear back from me after I replace the plugs, wires, dist rotor, pcv, and then check the error codes.
Look forward to contributing to this board.
