David ~ Welcome to the Corvette Action Center Community ~
AND welcome to the L81VetteRegistry
Cruise Control not working... most likely it's the transducer, could a fuse, but I'd bet it's more than likely the transducer
. The transducer is located on the drivers side, just find and follow the Speedometer cable to the unit
Choke Light stays on... First thing to try is to disconnect the Battery, this will reset ALL codes. If the light comes back, then it could be anything from a bad connection, ground or ??
Antenna not working... Check connection at the antenna motor, above the driverside muffler, check fuse's, this could be a a motor bad, it could be the plastic track inside the antenna and motor, could be at the radio end
More information would be nice, does the Cruise Control work at all, does the speedometer seem to work ok, etc??? Does the Choke light come on all the time, does it stay the same brightness, does it dim when accelerating etc. ???
Can you hear the antenna motor run when you turn on / off the radio, is there voltage at the motor, etc. ???
Also I suggest finding a GM 1981 Corvette Shop Manual #ST-364-81 and a 1981 Assembly Manual is very useful
Ebay usually has a few, or there are aftermarket vendors that sell them. The SHOP Manual is the best investment you make, esp. if you plan to work on your 1981 + the membership here, esp. in the L81Registry Forums here at the Corvette Action Center :dance GREAT Bunch of owners
Welcome aboard, enjoy the
Bud
