1981 Original Parts
Barry08
Portage La Prairie,Manitoba Ca
1981 Victory Red
Upgraded to a better engine on my 81. Have a lot of original stuff for sale.
Carb,distributer,air cleaner assembly,smog pump,magnesium valve covers
shields etc. all from a low mile 57,000 kms.If you are restoring your 81 I may have stuff you need!!!!
Barry
as of July 2016 1981 parts I have avail are: distributor excellent cond, smog pump with elect and hoses, orig GM AC Delco ACcompressor needs rebuild, exhaust manifolds set-nice), exhaust manifold heat shields, alum ribbed valve cover set, rear spring rear bolts iwth bush 6.5 inch, used cam, orig GM intake manifold. Orig heat riser valve with new vac unit, hood catch bars (the ones on hood with bolts/spacers), a/c compressor brace bar from A/C comprsr to manifold, front wheel bearings set with grease packing tool,
\Needed--spare tire carrier, complete or any parts.
thanks
Nick
