Vette79
Sounds like you are as bad as me. I will probably never ever use the defogger but it is the fact that it is there and does not work.
My mistake. No relay. Just a connector in the rear left quarter panel.
Diagram shows 30 amp fuse for the defrost on circuit with orange and black wire. Guage fuse also has something to do with it on the pink/black wire. Coming out of the switch is a black to ground. a purple that goes to the connector in the rear left quarter and switches to a black which terminates at the grid.
Check your grid lines on the window a worn one could cause a problem.
Jim
Diagram is pretty hard to read. If you are correct, this would make things easier eliminating a seperate relay under drivers side dash. Is the CB normally closed? If so, I could check for continuity accross the terminals to verify it is good right? Same with the fuse. Otherwise, it would be a bad connection or ground elsewhere. I thought for sure there was a seperate relay. Can anyone say for sure?
